Ap1 irregular idle after coolant change
I flushed and changed the coolant in my 2001 motor I have in a lotus 7. I flushed the system with water twice and the idle was normal 1k rpm. When i drained it the 3rd time and added coolant and bleed the air best I could the revs are bouncing from 1500-2000 or steady at 2000 rpm. I know this is commonly an idle control valve issue and I cleaned all the carbon out of it. I feel like it’s sonethibg else causing the irregular idle since it idled fine before changing the coolant. Prior to changing coolant I had the intake Manafold off to get powder coated. I doubt that had anything to do with it since it idled correct during the coolant flushes.
Did you replace the intake manifold gaskets, after the powder coating? Surfaces were clean?
yes replaced the gasket. Funny thing is I used the original gasket when I flushed it and it was leaking coolant a few drops onto the transmission but it idled fine when it was leaking. Replaced the gasket with another oem.
