ap1 head on my ap2
Old 06-22-2010 | 07:31 AM
ShawnM's Avatar
Default ap1 head on my ap2
Hey guys,
just got done searching regarding this topic, but i still have some questions about putting the ap1 head on an ap2. I have an opportunity to pick up an ap1 head with 46k on it for a great price, to mate to my ap2 with 42k on the odometer.
I've seen that the specs between the cams are different, with the ap1 having a slightly higher/longer lift/duration. I'm assuming this is a little more efficient at higher RPM's?
Also, I have seen mentioned a couple of times that the retainers are different? something about being vertical vs horizontal? I just want to know if the head will literally bolt right on, and whether anyone has done it before and can speak from first hand experience, as I didn't see that in any of the threads that came up for my search.
I'm not doing this for power or to "be able to rev to 9k." I've had a bad misfire and pretty shitty compression on this car that I'm trying to solve, as I believe it to be a bent valve(or more) in my stock head. I'll do a leak down before I buy the ap1 head to be certain...
Anyway, will the head bolt up? what else will I need to do this? just an upper engine gasket set?
Thanks for the insight
Old 06-22-2010 | 10:07 AM
Tanikins07's Avatar
What year AP2?
Old 06-22-2010 | 10:35 AM
Stratocaster's Avatar
The heads are the same for all NON-DBW S2000s. Only the cams and a few others parts (spring and retainers) are different.
Old 06-22-2010 | 01:18 PM
ShawnM's Avatar
sorry, I didn't mention that,
my car is an 05.So the head will bolt right up, no problem?
Old 06-22-2010 | 01:21 PM
Kermdaddy's Avatar
It should, but I want to add the AP2 head is stronger than the AP1. Everyone has their own reasons, but I wouldn't go backwards IMO. I would install a new head gasket while you had it off.
Old 06-22-2010 | 01:47 PM
street_ruler's Avatar
its the retainers not the head. just swap your old retainers or get new ones and you;re golden
Old 06-22-2010 | 01:48 PM
ShawnM's Avatar
well, as I mentioned, I'm looking at getting a full ap1 head for only $300. I'm certain any work I have done on this head will cost me significantly more.
I mean, is there REALLY any danger? I think with the mileages are so similar then it shouldn't be too much of a problem if the head is actually healthy and in perfect working order
Old 06-22-2010 | 02:10 PM
Shawn
The head casting is the same for 00-05. The cams, spring and retainers are different between the AP1 and AP2. The cams are the real difference as the other parts are minor and exchangeable between AP1 and AP2.
So in SHORT. Yes, It is bolt and go.
Old 06-22-2010 | 03:57 PM
ShawnM's Avatar
thank you for the straight forward answer
Ludeboye1
03-06-2018 03:50 PM
Pfieffdog
10-17-2016 06:05 PM
Honda Z06
01-07-2014 06:20 AM
blackAPtwo
02-26-2008 01:26 PM
enrique_s2k
08-19-2007 01:43 PM
