Is this an AP1 flywheel?
how much does it weigh ?
Looks like an OEM AP1 flywheel to me. (I've changed probably around 40-50 S2000 clutches, so I am very familiar with them.)
Here is a thread to back up my claim. You can see the clear differences between AP1 and AP2 flywheels and the identifiable casting differences that make yours an AP1.
https://www.s2ki.com/s2000/topic/106...l-differences/
Ah yes, it is indeed. I didn't catch that with the rust on there. With it being 11-12 pounds I can't say for sure what brand it'd be. It's very similar in shape to the AP1 OEM flywheel. Fidanza maybe?
Bottom line, any chromoly flywheel you run will be great. I would definitely use it.
Find some one to properly "step grind" the flywheel.
1 measure current step-height
2 remove dowel pins
3 grind friction surface
4 grind PP mounting surface to original step-height
5 re-install dowels
Stay away from aluminum flywheels.
2 remove dowel pins
5 re-install dowels
