Ap1 engine tick (in head)
Old 04-12-2009, 07:53 PM
  #21
LlamaS2K's Avatar
Sorry man, I have no clue. Although, i was using the same oil at the time.
Old 04-12-2009, 09:55 PM
  #22
RedSex2k's Avatar
Oh man, from that video it sounds like you spun a bearing or something. Have you over-revved the engine before?
Old 04-12-2009, 10:07 PM
  #23
savesday04's Avatar
Originally Posted by ryan111987@hotmail.com,Apr 11 2009, 05:22 PM
i dont understand how the timing could be off with a timing chain?? can you elaborate... i haven't gotten on the car since i heard the noise.... so idk if it sluggish... its just weird that the noise goes away on a downshift or when there isn't a load applied.
I doubt its the timing unless you have messed with it and just because its a chain doesnt mean the timing cant be off. It can still skip a tooth if the chain is too loose.
You need to find out for sure if its from the top end of the motor. If the noise is coming from the bottom end its possibly a bad bearing.
Old 04-13-2009, 01:38 AM
  #24
jkuamoo's Avatar
in my mechanical experience-
that sound is def. a rod knock.
if the sound goes away with a down shift-it is done by the vacuum in the chamber decreases load on the piston.
there is a small chance it could be a valve tick, but it is highly unlikely. if it is and goes away with adjustment, you are very lucky.
when was the last time you had a valve adjustment?
i hope i am wrong cause a rod knock would mean your block would need a rebuild.
rod knock is when the bearing in between the crank and rod has worn uneven and has been starved of oil. thus, damaging both the rod and the crank. its tough to say, but once you hear the noise-it has done enough damage requiring a rebuild for the block.
i hope i am wrong though because if this is true it may cost you.
Old 04-13-2009, 05:45 PM
  #25
ryan111987@hotmail.com's Avatar
yea, ive pretty much came to the conclusion that its a spun bearing also... its the only thing left... we check all valves, comp test (190 across the board), checked all the retainers.... i guess the sound is just resonating up and sounds like its coming from the head.... guess its time for a rebuild
Old 04-13-2009, 08:13 PM
  #26
s2kVTAK's Avatar
add me to the knock list. sorry to hear it man. as soon as i heard that video thats what came to mind. on these ap1s you gotta stay on top of the oil. i check mine every saturday morning now.
JB Morrison
10-17-2018 05:09 AM
BoostedE21
08-15-2016 12:40 PM
oc_s2k
11-05-2011 10:48 PM
Jacksparrow
11-05-2009 02:58 PM
luegos2k
12-18-2008 09:24 PM
Quick Reply: Ap1 engine tick (in head)
