View Poll Results: Clutch buzz or trans rebuild needed
Trans rebuild needed
0%
Voters: 1. You may not vote on this poll
AP1 clutch buzz or time for new trans?
hello everyone I’m new to the forum and first time posting out of desperation for help.
just purchased ap1 29k miles 2000
it just got delivered to me this morning and took it to the shop for inspection. Test drive was fine. However when it got on the lift and rev ed engine, this sound was heard every time tech stepped on the gas.
one tech says it’s well known clutch buzz other 2 tech says something is broken off or loose inside of trans and needs rebuild or remanufactured one..
which tech is right based on YouTube video below?
thank you for your help.
i hope it’s just normal clutch buzz
https://youtube.com/shorts/kySQSqJHww8?si=aJhgpoWf4jixCnOa
If it's an OEM clutch it's probably buzz and a rattling fork. If it's an aftermarket clutch, it's the clutch.
windhund116 (09-14-2024)
Clutch buzz happens on decel, and with load (car in gear). Its very noticible in cabin.
This doesn't seem like clutch buzz, for several reasons.
It has noticeable clutch buzz in cabin when driven. I am just wondering the sound in the clip is the clutch buzz I am hearing from cabin or other transmission problem that would cost me $$$
Thank you for your input. The car is in gear and the rear wheels are spinning as the tech is reving.
Its this reverse momentum that illicits the buzz. The wheels and drivetrain by themselves (hanging free on a lift) do not have enough mass, hence not enough momentum, to recreate the environment in which buzz buzzes.
The wheels spinning in the air isn't enough load. On the road, when lifting off throttle, the cars entire mass, combined wirh its speed, provide a significant momentum, that pushes against engines resistance to turn (primarily its compression), and which travels through drivetrain, including clutch.
Does not sound like clutch buzz. May be something related to the clutch though. If you are certain it is coming from the trans area, time to pull it and inspect the clutch first to see what is going on. Rebuilding these transmissions is getting harder as a lot of the parts no longer exist new. You can get synchros and stuff if you look around, gears 2-5 are non existent new as are some other items. But either someone beat the living shit out of the transmission (they do not just fail often on this car) or it is some noise related to the clutch. There is really no good way to get a good look at the clutch without pulling the trans though. You can pull the slave and stick an inspection cam in but cant really see enough other than if there is shrapnel in the bell housing.
But one data point you have is it appears this only occurs when the car is NOT under much load, if you do not hear it all when driving it but do hear it on the lift. It only happens on the lift when in gear? Does it continue in all gears or just specific gears? Does it do it all in neutral when on the lift and revving it?
