Ap1 bottom 2.0 and Ap2 2.2 head will this work?
Old 12-02-2010, 04:36 PM
super2k's Avatar
Default Ap1 bottom 2.0 and Ap2 2.2 head will this work?
Ap1 bottom 2.0 and Ap2 2.2 head will this work? my ap2 engine gave out, but my friend is selling his 2.0 bottom for dirt cheap , will this work on my ap2 head..?? can i get an insight of the pros and cons or am i just trying to take the easier way out !!! my 07 ap2 just sitting out without motor need to know where to start...!!!!
everything is good now runs good no problem turbo is good too thanx for all your help. it was costly and time consuming for one error plus i have to down grade to a 2.0 crank, but i still kept my ap2 block and head . my s2k is alive and kickin now i have too keep it that way..
Old 12-03-2010, 12:27 AM
KC2001AP1's Avatar
YES IT WORKS ,JUST SWAP THE CRANK POSITION SENSOR THEY ARE DIFFERNT .OTHER THEN THAT YOUR GOOD
GOOD LUCK.
Old 12-03-2010, 01:16 AM
2003AP1's Avatar
Damn your motor on your 07 gave out?
Old 12-03-2010, 05:12 AM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
Crank sensor is the same
Old 12-03-2010, 06:30 AM
GoFaassttt's Avatar
Wouldn't the AP1 block rev limit be 8000 since it is being run by an AP2 ecu?
Old 12-03-2010, 06:32 AM
super2k's Avatar
i installed greddy kit and installed the oil filter re locator hose wrong , went on the dyno to get it tuned then boom!!
Old 12-03-2010, 06:41 AM
TruBluS2k's Avatar
ouch
Old 12-03-2010, 07:51 PM
H22toF20's Avatar
Expensive, time consuming, labor intensive mistake.
Old 12-05-2010, 12:02 PM
ILOVEMYAP2's Avatar
hey man whats i got all the answers to ur ?'s
i have a 2006 and i have a 2001 block with my 2006 head and my car runs perfect have no problems with it its also turbo
what you need to do to make this work is put ur 2007 crank sensor and the the crank wheel in the ap1 block thats it
Old 12-05-2010, 12:05 PM
ILOVEMYAP2's Avatar
00-05 the crank sensors are the same and the crank wheel but 06 -09 there different
Quick Reply: Ap1 bottom 2.0 and Ap2 2.2 head will this work?
