Are AP1/AP2 rear spindle/knuckle ass. the same?
I need a rear spindle assembly and im about to purchase one from here very soon but is AP1 and AP2's the same? I would imagine so, THANKS
you can check as well as anyone else, but since you haven't, i'm gonna assume there's a good reason, so...
AP1 (03):
52210-S2A-000 003 001 KNUCKLE, R. RR. 219.70 158.18 Qty:
52215-S2A-000 004 001 KNUCKLE, L. RR. 219.70 158.18 Qty:
AP2 (04):
52210-S2A-010 003 001 KNUCKLE, R. RR. 232.60 167.47 Qty:
52215-S2A-010 004 001 KNUCKLE, L. RR. 232.60 167.47 Qty:
so, in conclusion, no, they are not the same. do with it what you will
AP1 (03):
AP2 (04):
You may be ok if you replace both sides and perhaps the assembly, but AP1 and AP2 knuckles are NOT the same.
There are slight angle differences on the knuckle. So while it may roll straight, I had noticed the weight shifting on the rear to be unstable during my track day. It was more twitchy on double apex turns as well.
Replaced it again with AP1 knuckle and the rear end is stable and happy.
There's a reason for the difference in part numbers.
Front spindles are interchangeable between AP1 and AP2, but not the rear.
S2K VINCE (09-13-2024)
