AP1 with 90k miles low compression
I've had my AP1 for just about over a year and it had 69,000 miles when i got it. After driving it for approx 16,000 miles (85,000 on the odometer) the CEL comes on when i was very low on fuel. Went to pepboys to scan the codes and there were 3 codes: 301, 302 and 300.
So now, i try to figure out what caused the CEL to come on.
Step 1: changed the spark plugs with some ngks, deleted the codes then a few days later, CEL came back on.
Step 2: deleted code, switched coil pack #1 with #3 deleted the code again but it came back on a few miles later. Scanned it, now misfire on cylinder 1, 2 and 3. I thought it was the coil pack so i purchased 1 new coil pack and changed the one that i thought was faulty. As usual i deleted the code and guess what, it comes back on again. Now with a random misfire code. I switched the new coil pack to every single old one but the light kept on coming back.
Step 3: Compression Test. The numbers were:
Cyl #1: 130 PSI (dry) 190 PSI (wet)
Cyl #2: 100 PSI (dry) 130 PSI (wet)
Cyl #3: 220 PSI (dry)
Cyl #4: 200 PSI (dry)
The tests above were done at 90,000 miles.
Im a bit worried that i might have to rebuild/change the bottom end.
Any suggestions on what other options i have? Any other more conclusive tests that i should do? Thanks in advance for your response(s).
![](https://www.s2ki.com/forums/images/s2ki/ranks/moderator.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Yes cylinder 1 and 2 are real bad.
Get someone whos knows engines to do a leakdown test. The right guy will tell you if you have scored walls, bent intake, or bent exhaust valves.
I think you have burned/bent valves in at least cylinder #2.
You're best bet right now is check your valve clearances. There is a moderate to fair chane you could cure it with a valve adjustment. If if you dont, you will have at least found your underlying issue that burned the valves (tight clearance) This is important, so as not to repeat history
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
Billman250, are you saying that based on the "wet" test results there is still a chance that the problem that my engine's has is coming from the head?
Here are some facts that might help diagnosing the problem:
Oil consumption is at about 1/2 quart every 1200 miles
The car is bone stock and i've personally never tracked it.
It gets an average of 24mpg/28 hwy mpg.
I don't feel much of a powerloss and the engine is fairly quiet.
Vtec engages just fine.
Doesn't smoke at all.
It has a VERY slight(very few people notice it) misfire while idling
