Anyone running a unsprung clutch?
Might be trading my VW for a S2K this weekend. There are a few things that bother me about the car and one of them is that it has a unsprung clutch. Just wondering how bad will it suck in a street car? I know I need to test drive it but we actually live 7 hours apart and are meeting halfway. Please give me some insight if you can. Thanks
The car is in PA. Has Megan coilovers, headers, test pipe, Invidia catback, replica Works wheels, 135k miles, maintained well. Also has big horseshoe shaped scratch on quarter and small tear in the top.
Wouldn't pay more than $10k for that to be honest. There's a reason stock cars hold their value more, if this guy did everything right then you should request alignment sheets, check the condition of the tires, look at the upper control arm bushings and see if they're torn. Remove the wheel caps and look to see if the axle nut has been torqued properly. Then open the hood, and look for leaks, if they engine bay looks too clean it means he cleaned it, which means it's leaking somewhere. Obvious spot is to run your finger under the TCT, if you pull a little line of oil there's a leak somewhere. If the clutch feels heavy chances are it's on it's way out, it may last another 10-20k miles. If the rear quarter panel is damaged there is no OEM replacement, just letting you know.
Unsprung clutch feel depends on the clutch itself. There are ones that are somewhat streetable and others that are not. I had an ACT unsprung clutch in an S2000 that I owned that was pretty easy to drive on the street but I still wouldn't recommend it over sprung clutches.
i have driver on the street for years in my younger years with single disc puck style unspring clutches and i would not even recommend it for a daily driver. They are great for racing but for daily stop and go traffic it will make you hate your car. Drivability is hugely impacted.
The fact that the hub is unsprung has little to do with the harshness everyone complains about. Most unsprung discs have an aggressive friction material that causes the drivability problems. The lack of a marcel spring (large flat wavy washer) between the friction faces also contributes. I've run an organic faced solid hub disc and it was fantastic in my daily.
