Anyone reuse washers on tranny/diff. fluid changes
Has anyone tried reusing the washers when doing a tranny or diff fluid change? I was curious if it was ok to reuse them.
Originally Posted by gernby' date='Feb 1 2005, 10:23 AM
I usually don't reuse them, but if I do, I flip them over.
Note: I have ordered a few of them from Hardtopguy the last time I order filters and other misc parts. So Now I have them.
The washers are directional, if you look at one closely you will see a flat and a convex side, the flat side goes against the case whether it is the tranny,diff or oil pan. I make a effort to keep them on the plug when off and they will not get on wrong.
Cya Pete
Cya Pete
I've re-used them many times. I don't flip them since I noticed that the washers develop an "impression" or indentation mark and I don't want to risk flipping them in case these impressions don't line up.
The only one that really needs close attention is the diff fill bolt washer. It appears to be made of a yellow metal and it is much solfter. In time, this washer can squash very thin.
