Anyone Here Has The Helms/service Manual For S2000
If anyone has this manual i need to know the size of the oil bolt on the part that goes on the engine not the part that faces the filter thanks. is it 20mm 22mm ?
yes i am asking about the part that holds the oil filter, oil cooler by screwing onto the engine block. I need to know the thread size of the piece that goes on the block not the side that goes on the filter thanks.
Replied to your PM.
Here's the info for anyone else who's interested.
It's Honda part# 11107-PT2-000 according to my catalog. They don't specify anything about the threads unfortunately (but not surprising). It's the same part used in 1991-1993 Accords and 1995-1998 Odysseys if that helps at all.
J.P.
J.P.
humh that helps a bit because i know is bigger so i m expecting it to be 22mm then. thank although it could be less but i think they usually go in even numbers 18 20 22 thanks
