anybody know where the Water and Oil Temp sensor?
a buddy of mine is installing water and oil temp gauges
just wondering where's the sensor for water and oil temp?
thanks
and anybody know how to install them?
thanks
thanks
thanks
The water temp sender is located at the very back of the engine next to the firewall. You will not get at this easily without lifting the engine. Additionally, the ECU needs the OEM sender signal. There would be no room to "T" another sender into this. You are better to find a different location. Here is where I put mine:
https://www.s2ki.com/forums/index.php?showt...l=gauge++sender
There is an OEM oil pressure sender tapped into the front of the engine. You could "T" into this for your temp sender, however, there isn't proper oil flow there to register a good oil temp reading, plus, you'd need to use a steel line to remotely mount the sender due to the weight of the sender possibly cracking the fitting. This remote mount would also make for a bad temperature read. You are best to install a Greddy oil filter adaptor and put the sender there. This, too, will not give a true oil temp reading as the oil filter mount has a water cooling jacket, but this is better than your other choice.
Are there any differences in oil pressure readings using the greddy sandwich adapter as opposed to tapping right off the stock oil sender?
Originally Posted by Venomous S,Apr 26 2005, 08:19 AM
Since we are on this topic
Isn't the best spot to take the oil temp in the lower pan? I've always been told that it's the most accurate reading due to the volume and how it'll keep you from seeing wild fluctuations, hot or cold spots in the block/head, etc....
Originally Posted by SpoonTypeR,Apr 26 2005, 10:32 PM
can i just tapping to water temp and oil temp sensor?
or i have to build one like u did?
jeremicium
07-31-2013 08:48 PM
johninator
04-22-2011 12:45 PM
Imarriedmys2k
03-17-2011 12:27 PM
Russ
09-04-2002 12:40 PM
