Any tried to duct intake to vented hood?
Thinking about trying this... building a duct from the J's vented hood to the filter box, since the stock airbox is RIGHT under the vent. Anyone tried this or think its a bad idea?
I think it's a bad idea because the shape of the J's Racing hood is designed to draw air OUT of the engine bay. So instead you'll be sucking air out of the intake.
I cut out a chunk of the bumper under the headlight and inserted a NACA duct. I also sealed up the inside of the wheel well so all the air goes up into the intake instead of shooting off into the cracks. Here's a pic of the original duct...I've since replaced it with a proper black duct that fit better and looks a lot cleaner.
If you wanted to use hood "vents" to draw air into your intake, you'd need a true cowl induction hood (air is drawn in towards the back of the hood, at the cowl). As Elistan pointed out, the purpose of the vented hood is exactly that: to vent air out.
Anyone else see the irony?
