any pointers on plastigage for the cam journals
So I have never used plastigage before. I am going to pick some up from autozone and measure the cam journal clearance. My question is once I take the plastigage reading what do I compare it to? the other journals, or is there a value that it needs to be within?
Camshaft to holder oil clearance is 0.002-0.004in
Service limit is 0.006in
That's directly from the helms manual.
You should get plastigauge (looks like dental floss) as well as a strip of paper with measurements on it. When you torque it, you can use your measuring paper to determine the width. Then you can compare it to the value above.
so when you torque down the plastigae what we are basically measuring is the thickness? thats an awfully small amount to measure with just your eyes.
alright after doing some searching. You pretty much have a set amount of the plastigage, then you put it somewhere near the middle of the journal, torque the caps to spec, and then measure the squeezed plastigage to the specified chart that they give you. Should be fairly easy I guess.
I'll probably do the same journal 2 or 3 times to make sure that there is a decent average. Just want to rule it out or in as a problem for my oil pressure.
Once you do it, it makes a lot more sense than the explanation.
