Any Other HKS Owners have this problem? =(
Just got the exhaust installed and it sounds AWESOME!! But there were a few glitches. My left exhaust was higher then my right one and when I got home, the plastic molding had melted. ANyone have any thoughts on how to adjust the exhaust? THe guys that installed mine were telling me that I needed some kind of special HKS bracket or something like that. PLEASE HELP. =(
i had the same problem....wat did is loosen all the bolts...adjust it....make it even and then slowly tighten it back....it's fine now....
hope that will help.....
Hey, if your name is S2000Spoon, how come you got HKS?!
It must be touching for it to have melted your plastic. I noticed my left was a little higher when I installed it. I just loosened the bolts on that side and readjusted it. Make sure your rubber hangar is on correctly too or it could also raise the exhaust canister.
Good luck.
Good luck.
9000RPM, when I had it on mine, I didn't have any problems (Perfect install). As far as I know, there's no "special HKS bracket" it came with (I'm sure other HKS Hiper owners can back me up on this). The only thing I can tell you is redo the install just like everyone else here is telling you how to do it (loosen the bolts & adjust). LMK, if you have anymore problems.
mingster...
at that time the spoon exhuast wasn't availble...also i wanted the dual exhuast look....love the sound and the power of the single exhuast that the spoon made but...i went with the dual look.....
plus Hks is more geared towards turbo cars...they just made the right exhuast at the time.....
Thanks to everyone for their help!!! Now the left side is a little lower then the right though! =O As long as it doesn't touch the plastic I'm happy! =) WOOOOOO HOOOOO that bad boy sounds GOOOOOOOOOD!!
toplessPolak
01-20-2014 09:29 PM
