any options for rearend replacements?
Old 01-20-2003, 09:57 PM
Schatten's Avatar
the stock rear end on the S2000 is 4.1.
but say you get another rear end and perhaps axles with the narrow wheel base to match and mount that up there - if its american made, like say an 8.8 ford rear end - the gears are CHEAP - like $179 cheap, come in lots of different ratios - 4.10, 4.56, etc. so yes, you can modify it to gear up with the S2000. other issues you'll run into are suspension components and of course.. the driveshaft. as you know, we have cv joints, not u-joints for the driveshaft, so its not typical. you'd have to do some fab on this, but it would be worth it because it would hold up to just about any hp rating and clutch setup that this car would push.
Old 01-20-2003, 10:10 PM
jerrypeterson's Avatar
[QUOTE]Originally posted by Schatten
[B]the stock rear end on the S2000 is 4.1.
Old 01-20-2003, 10:47 PM
RT
RT's Avatar
dude your diffs fine .... you drive like a pu$$y ...... j/k
Old 01-20-2003, 11:41 PM
[QUOTE]Originally posted by RT
[B]dude your diffs fine .... you drive like a pu$$y ......
racer-rob
07-10-2002 06:44 AM
sy2kwa
05-24-2002 06:03 AM
muppet
10-29-2001 10:18 AM
ken reich
10-01-2001 10:00 AM
jschmidt
06-08-2001 05:33 AM
Quick Reply: any options for rearend replacements?
