any honda techs in the house? I have a good one...
So I bought a car with bad engine. ECU was not original but car started and ran(with engine knock).
The engine was replaced on the car and now the car doesn't start. All grounds, starter, fuses were checks and appears to be good. My question is, do I have to reprogram the ECU when I swap engines? The ECU is SAME one that was there when the car is running. I assume I don't but now I don't know. I am stuck. The car has been to two mechanics and no one seem to know what is going on. Maybe someone here works in honda dealer can give me some pointers..
Btw the lights on dash all go on and starter seem to be clicking but engine would not even try to turn.
Originally Posted by Slows2k,Jul 21 2008, 03:45 PM
Usually the ground on the back of the cylinder head gets forgotten.
Originally Posted by Slows2k,Jul 21 2008, 03:49 PM
If you can't see or feel the wires attached to back of the cylinder head then they aren't bolted to it.
Starter clicks but no turn. hmm... Have you tried to turn the engine over at the crank pulley bolt while in neutral to make sure your new engine isnt locked up? may check the wiring to the starter too, or is it a starter that came with the new engine (not likely if an engine is all you got) that could possibly be a bad starter?
