Another s2000 engine rattle thread (with video sound)
Old 07-18-2024 | 08:19 AM
engifineer's Avatar
same here, fairly common on these cars as I have walked by others and heard the same.
Old 07-18-2024 | 03:12 PM
chasingdreams's Avatar
Thanks for the confirmation guys.
It is quite a scary rattle and only happens when warm but goes away when you apply throttle. Are you guys experiencing the same too?
I would imagine as long as the rattle doesn’t get louder with revs/throttle, then it’s ok right?
Old 07-18-2024 | 03:24 PM
noodels's Avatar
S2000 has slipper pistons,ie very short<less drag> like a race engine.Its all good
Old 07-19-2024 | 12:39 AM
Thanks Noodels!
Can I confirm the rattle was on warm engines? I see cold piston slap threads and goes away when warm. But not many of piston slap while warm but goes away with revs
Old 07-19-2024 | 05:57 AM
Billman250's Avatar
We are not talking about a rattle. This is a specific sharp tapping noise that comes and goes. 3-7 taps, then goes silent. Then returns. Then disappears. And so on…
This can happen cold, or hot. During hot idle, the spray from the oil jets is low. Just above idle, the oil spray under the pistons is mushroomed down when the piston is going down. The oil is forced into pinholes in the piston, directly flooding the piston skirts. It hydraulically stops the shifting of the piston, and the subsequent noise.
Oil exit holes, which originate underside of piston, directly about the skirt:
Oil entry holes, underside of piston:
The following 5 users liked this post by Billman250:
jnewtons2k (07-19-2024), KC2K (07-23-2024), noodels (07-19-2024), Slowcrash_101 (07-20-2024), windhund116 (07-19-2024)
Old 07-19-2024 | 03:27 PM
Thank you for the explanation and reassurance Billman. Appreciate it and I can finally enjoy the car. Cheers!
The following 2 users liked this post by chasingdreams:
noodels (07-19-2024), windhund116 (07-19-2024)
3AM
09-11-2020 09:49 AM
JaneDoeski
07-22-2019 09:50 PM
TRD_Celica
06-02-2014 08:04 PM
Bingoig11
08-23-2011 07:01 AM
F20Freak
09-26-2010 10:09 AM
Quick Reply: Another s2000 engine rattle thread (with video sound)
