Another s2000 engine rattle thread (with video sound)
Old 07-16-2024 | 04:30 PM
chasingdreams's Avatar
Default Another s2000 engine rattle thread (with video sound)
Hi there.
So some context regarding the engine rattle:
Engine idles perfectly fine, no engine rattle or any weird noises when it’s cold start.
The rattle only comes when the engine is at operating temperature during idle only.
If you rev it or slowly increase RPM, the noise goes away.
The noise is more prevalent on the header side of the engine (noise is still there with stock headers), or when under the car coming from the sump. Have checked if headers are cracked/loose bolts, no dice.
Can someone help with reviewing the video and letting me know their thoughts? Oil level is perfect too.
Cheers
Old 07-16-2024 | 04:36 PM
Forgot to mention, have also taken off the serpentine belt, replaced the bearings for the idler and tensioner bearings. When the serpentine belt is off, the noise is there about 10% as opposed to 90%, hence why I changed the bearings but still has the rattle there
Old 07-16-2024 | 05:02 PM
Billman250's Avatar
Take another video. 4 feet away from the front of the car, hood closed. This is the only way to pinpoint individual noises.
Another video under the car. Yes I know there is an oil leak, attending to it as we speak.
File Type: mov
Wow really?
I would have imagined it would make it more challenging to identify but I’ll give that a shot and upload when available
Old 07-18-2024 | 02:00 AM
Hey Bill,
Thank you for your patience.
Please see video attached as requested. Front of the car, hood closed. I did some further investigating, unplugging coils 1 and 2 make the sound completely go away if that helps.
Let me know if there’s anything else I can provide
File Type: mov
Old 07-18-2024 | 02:30 AM
Also done a tonne of research using the s2ki forums, this is as close as to what mine sounds like this from another thread:
There is also a lot of threads saying it’s normal and have driven tonnes of miles but I just want to be 100% sure, since no one has been able to find a fix or disappear from the forums/remove their video
Old 07-18-2024 | 03:54 AM
Billman250's Avatar
In the hood closed video, there is a tapping noise that comes and goes. Is this what you are talking about?
Old 07-18-2024 | 04:20 AM
Correcto. To put it simply it’s the rattle that sounds like “tk tk” “tk tk tk” “ddtk tttk ttkk tkkk”. The rattle every 0.3-0.5 seconds-ish
Old 07-18-2024 | 06:18 AM
Billman250's Avatar
That is piston skirt slap and exists in many S2000s including mine.
Im at 158k, it has been doing that for 80k miles.
The following 2 users liked this post by Billman250:
p3tah (07-18-2024), Save the Manual Wagons! (07-18-2024)
Quick Reply: Another s2000 engine rattle thread (with video sound)
