Another Flawed Wheel Alignment
Old 07-27-2010 | 05:34 AM
Shark's Avatar
Smile Another Flawed Wheel Alignment
I recently had wheel alignment jobs done on both of my cars. Both times, the alignment was fine but the steering wheel wasn't perfectly straight. And both times, I took the car back to have things adjusted only to be told that there wasn't a problem.
What gives? It seems as though eight to nine out of ten times they can't get the damn steering wheel straight. Sometimes it's pointed to the right, other times to the left. Of course, this determination is made on relatively flat roads. And of course, very few roads are indeed flat which complicates the troubleshooting process.
Should I just live with my slightly crooked steering wheels or keep going back until they are right? Then again, will they EVER get it right? Perhaps someone with experience in this area will chime in and provide insight to what seems like an impossible dream: a straight steering wheel.
For the record, tire pressures have been checked on both cars.
Old 07-27-2010 | 07:20 AM
takeshi's Avatar
Pick a better shop for alignments. Check your regional forum for suggestions.
Old 07-27-2010 | 07:51 AM
Shark's Avatar
[QUOTE=takeshi,Jul 27 2010, 10:20 AM] Pick a better shop for alignments.
Old 07-27-2010 | 08:17 AM
lman's Avatar
maybe because the alignment was off before so the tire worn out different from both side and so when they bring it back to spec it would pull to one side. just a thought.
Old 07-27-2010 | 08:35 AM
Shark's Avatar
This is possible, I guess. One of the car's had new tires installed at the same time.
Old 07-27-2010 | 09:34 AM
GPW AP2's Avatar
Where have you been going for the alignments? Check with the local autocross guys and see where they get them done. I have a local guy that I trust and would not go anywhere near any other shop.
John
andrewhake
46
10-31-2014 10:40 AM
roel03
10-20-2014 07:15 AM
KyungMin
06-17-2014 02:07 PM
aklucsarits
09-02-2004 08:24 AM
WRS2K
10-17-2001 09:49 AM
