Another engine tick
Another engine tick
It's been about 4 months since I had a ticking sound similar to this. All I had to do was replace the timing chain tensioner and it was gone. Seeing that it has only been 4 months, could the tct possibly be the problem again???
BTW this is the sound I'm hearing
http://www.youtube.com/watch?v=Y8hYA87DMIM
Thanks!
Thanks!
Originally Posted by da_wesmeista' date='Jan 14 2009, 10:35 AM
I'm going to check to see if the tct is torqued down properly and if that doesn't fix it I'll go with the valve adjustment.
Originally Posted by da_wesmeista' date='Jan 14 2009, 07:35 AM
thanks for the advice. I'm going to check to see if the tct is torqued down properly and if that doesn't fix it I'll go with the valve adjustment.
well the tct was bolted down just fine... surprise surprise
I am having the valves adjusted tomorrow and have a tct from htg on the way just in case. Hopefully that will fix things.
Mintyhit
03-25-2011 09:59 AM
