Another brake dilemma
I decided to take a spirited drive home from work today and warmed my Carbotech AX6's (which are crap btw). It then felt like one of my right calipers seized up. Car pulled sharply to the right and when stopped at a light would feel like the parking brake was up a few clicks when creeping forward. I then stomped on the brakes and turned sharply to the left/right in an attempt to loosen it up (probably not the best idea I know). It immediately went away and I drove home normally.
After I got home and gave the car time to cool I went for another drive to try and replicate the problem to better see if I could figure out what happened. Warmed the brakes up, car did not pull and seemed to slow down from a roll normally. When stomping on the brakes however, it would veer violently to the left. The left front would lock up almost instantly and was making ALOT of noise. Then when I arrived at home I find that both RIGHT wheels were MUCH hotter than the left.
I'm confused
I'm confused
Sounds like your calipers are sticking. Check the sliding pins to make sure its lubricated and free of dirt. Otherwise, time for a caliper rebuild kit
What's wrong with the AX6? They work great from my limited experience on the street.
They work horrible when cold (which I expected being a track pad), work great when warm, and horrible and are extremely loud when warm-hot. They used to work great and silent when hot but not anymore. Have been on them for ~10k miles.
Huh... I would say your calipers are sticking also. I would pull the wheels off and do a through inspection and re-lube of the brake system.
I find it interesting you have issues with the AX6 pads. I run the XP10/8 combo and love them, I have ZERO issue when they are cold, hot they are phenomenal and have zero fade (rotors were heat soak blue after a dragon run and the pads never faltered) They can be screechy when stopping but I usually release then reapply the brake and the noise goes away... Mostly the noise makes me giggle
I reused the old ones. Probably should have gotten new I know. Ive been driving for 10k on them fine so I assumed if it was the shims it wouldve been from day 1. Think Im going to break down and get XP10/XP8 as i am very dissapointed in the AX6's.
Using the old shims is fine, but when you replace the pads take a good look at the dust boots on the pistons. If they have any cracks or holes chances are moisture entered and destroyed the pistons. This is what happened to my front rotors, the pistons had pitting and would catch periodically causing the brakes to stick. Hope this helps.
Originally Posted by 30r Dreams' timestamp='1312402462' post='20844031
My car had this exact same problem over a year ago. Did you install shims on the carbotech pads? If you didn't I bet I know what the problem is.
bluemetals2k
10-18-2013 04:02 PM
ap2s2klover
03-26-2009 05:43 PM
