ANNOYING NOISE
Old 12-08-2005, 10:38 AM
NFRAP1's Avatar
Default ANNOYING NOISE
I HEAR A METAL NOISE, ALMOST LIKE SOMETHING IS LOOSE.MY SHIFTER SEEMS LOOSE IT VIBRATES A LOT WHILE DRIVING, LIKE A BACK AND FORTH MOVEMENT.I HEAR THE METAL NOISE WHEN GOING OVER BUMPS AT SPEEDS OF 10MPH OR MORE.IT IS REALLY ANNOYING.. ANY IDEAS?I HAVE AN 00 AND IT HAS 60K MILES ON IT.
Old 12-08-2005, 10:45 AM
xviper's Avatar
YOU can TURN off YOUR caps LOCK now. WE can HEAR you JUST fine.
The engine is rubber and fluid mounted and the tranny is rubber mounted. It is typical for the shifter to move around. As for the noise going over bumps, try tightening down your spare tire or re-arranging your passenger seat and seat belt.
You could also be hitting the suspension stop with the bumps. No big deal.
Old 12-08-2005, 10:49 AM
NFRAP1's Avatar
Its not the passenger seat, maybe the spare tire, as i havent checked it.The noise seems to be coming from the front of the vehicle, I wanna say front, passenger side, up front like something suspension maybe.It is like a rattle noise, metal on metal, sounds loose.
Old 12-12-2005, 10:03 AM
NFRAP1's Avatar
Nope, It isn't the spare tire making me crazy either!!!!
I can't find the noise still....
Old 12-12-2005, 11:44 AM
xviper's Avatar
Loose, stick-on wheel weight?
Old 12-12-2005, 12:11 PM
NFRAP1's Avatar
I have Volk GTNSs...could be a wheel weight but I dunno
I'll have to get my car jacked up and take a look underneath, with a a mechanic friend of course.
Old 12-12-2005, 12:14 PM
xviper's Avatar
You should be able to reach through the spokes of the rim and feel each weight to see if they are good and stuck on.
Some years ago, a similar post was put up here be someone who had this sort of noise. Lots of diagnostics took place, with some trips to the dealership, resulting in nothing being resolved. It was much later discovered that one of his wheel weights were flopping around when he hit a bump just in a certain way.
Old 12-12-2005, 12:20 PM
NFRAP1's Avatar
Well, I really appreciate all your help, Ill check it out when I get my 04 bumper put on.Hopefully tonight!
Lew
08-04-2018 02:25 PM
Caffeinated21
12-15-2004 04:17 PM
SilverKnight
08-30-2004 08:25 AM
Optikal
05-10-2004 07:24 AM
moc8
11-01-2002 09:36 PM
Quick Reply: ANNOYING NOISE
