Amuse Hi Tech Rom
Amuse Hi Tech Rom
Ive searched the forum and ive searched the web, this is really all the info i could find.
Hi-Tech ROM
-Remapped fuel/ignition tables, VTEC crossover ~5850rpm, Revlimit ~9200rpm.
-Hi-Tech ROM VR (Timing Retard Control via knock sensor) also available.
-Hi-Tech ROM RS (Timing Retard Control when IAT<60
Hi-Tech ROM
Basically it's tuned just to compensate for fuel quality and location...
They remap fuel and Timing and adjust Vtec switch point...
The VR retards timing based on bad fuel like lower octane san Ron 98 vs Ron 89
And the RS will retard timing based on Weather conditions thats why it mentions the Intake Air Temp and Engine Coolant Temp.
The only changes made is how agressive the tming map is on each ECU and the fuel is just compensated based on timing.
Well i always use 98 RON so i wouldnt need the VR, the RS sounds good as it gets pretty hot sometimes. Thanx laguna uve been a big help.
Is there anyone on the forum who has a high tech ROM??? Id really like to hear from someone with first hand experience.
