Amsoil 75W90 Synthetic in the differential
Old 12-20-2011, 09:49 AM
deepbluejh's Avatar
Default Amsoil 75W90 Synthetic in the differential
I made a big purchase with Amsoil last week for engine oil (0W30 Signature synthetic), Transmission oil, and differential oil. I followed their recommendations and got 75W90 EP synthetic ( http://www.amsoil.com/catalog.aspx?code=SVGQT-EA ). While doing research on the forum I find that most people recommend the 75W-110 in the diff instead as it most matches the OEM spec.
Amsoil recommend a 50k change interval for this oil for "severe duty" while the OEM change interval is 30k miles.
So my question is will this oil be ok for the diff or should I ditch it and get the 75W-110? I live in Atlanta and it's fairly warm here. I don't race my car, but I do drive fairly aggressively on the street at close to stock power.
Old 12-20-2011, 09:55 AM
INDYMAC's Avatar
I have never heard of a S2000 diff failure using SAE 110. We have lots of diff failures reported on this website. Your call, it's your money.
Old 12-20-2011, 10:00 AM
deepbluejh's Avatar
There are so many holes in this logic I can't even begin to address it.
Does anyone with direct experience with 75W90 have any comments?
Old 12-20-2011, 10:24 AM
starchland's Avatar
always ran 75/90 regardless of it being too thin at operating temp. 3 summers of motul and just put in amsoil. changed once a season.
Old 12-20-2011, 11:35 AM
Chris_Lum's Avatar
i used 75w90, can't remember which brand, but my diffs started to make noises after the 2nd change. Researched the noises and found out it could lead to a blown diff. Upon recommendations from those that had the same noises, i changed to Motul 90PA and the noises went away. It's been 12k miles so far with no more noise and no blown diff for me!~
Old 12-20-2011, 12:06 PM
deepbluejh's Avatar
That's the first time I've heard something like that. What were your change intervals like? I might just hold off on changing the diff fluid for a while.
Old 12-20-2011, 12:12 PM
JohnsS2000's Avatar
PuddyMod Racing (Ben) told me that the Amsoil 75 - 90 severe gear is good. I have 2 qts for the next 2 changes. I am getting ready to install a PuddyMod rear diff and he puts the 75-90 severe gear in the builds he does.
Old 12-20-2011, 04:20 PM
deepbluejh's Avatar
Thanks guys. I went ahead and changed the diff fluid out with the Amsoil 75w90. I'm sure it'll be fine.
Old 12-20-2011, 05:17 PM
Whoabitchin's Avatar
We run the 75W-110 because the specs changed on the 75W-90 weights since the when the car came out. The 75W-110 actually is closer to the original OEM 75W-90. I cant remember the specifics but the info about the change is on here. The 75W-90 should be fine though.
Old 12-20-2011, 06:21 PM
Chris_Lum's Avatar
My intervals were the factory recommended, 15k i believe? never launched or abused the diff. I owned the vehicle since it had 9k miles too, and was completely stock when i bought it, so pretty sure the previous owners didn't abuse it either.
anyhow, this is the thread i started a while back. I researched the forums up and down and not many people had the exact problem i had, but Kyras was kind enough to discuss this issue on the phone with me and her husband had the exact same problem : https://www.s2ki.com/s2000/topic/833...er-or-shudder/
excerpt from the thread:
Originally Posted by Spokes Man
As Patty (Kyras) mentioned above, I switched to the LE-1605 in my '06 S2000, and have had no problems with over 42k miles on the car now.
I had the original differential lube changed at Aliso Viejo Auto Service when the car had 13,500 miles. They used Mobil One 75W90 gear lube, and my car immediately started making rough, grinding noises during low speed tight turns. Not only could I hear it, I could feel it! I had the mechanic check the car, and he claimed he felt nothing. However, it was very noticeable to myself and Patty, and she had experience with the diffy going out in her '05.
After doing some research in the S2ki "Under the Hood" Forum, I found a write-up by "Road Rage" that recommended the LE-607 Almasol which was later replaced by the LE-1605. I ordered the LE-1605 from "Ricks2k," and had Aliso Viejo Auto Service replace the Mobil One 75W90 with the LE-1605. The diff immediately stopped making the rough, grinding noises, and has been smooth as silk ever since with continued use of the LE-1605. Unfortunately, they no longer carry the LE-1605 lube at Aliso Viejo Auto Service, so I supply it myself.
I know that some S owners have used Mobil One 75W90 successfully, but my car did not like it. I would agree that it is better to use a single viscosity lube in the differential rather than a multi-viscosity...especially in our SoCal climate. Once the car reaches proper operating temperature, I doubt there is any loss of hp.
Just my .02-worth.
As he says, not everyone seems to have this problem, but for those that do, we suggest switching to the LE or the Motul 90pa.
Quick Reply: Amsoil 75W90 Synthetic in the differential
