amsoil...
Old 01-19-2006, 09:47 PM
S2kracka's Avatar
It probably won't hurt your engine, but a regular 10W-30 would probably provide better protection unless you drive in VERY cold climates. Where are you located?
Old 01-20-2006, 05:22 AM
S2000GT's Avatar
Originally Posted by S2kracka,Jan 19 2006, 11:43 PM
People really need to keep their mouths shut unless they actually know what they are talking about. This is happeneing far too frequently on this board lately.
I think part of the problem is that people are posting these more "technically challenging" questions in the wrong forum. There is a tendency for them to be answered with hearsay rather than actual experience which is potentially dangerous. I am going to move this to UTH where you should hopefully see a better response.
Old 01-20-2006, 05:24 AM
vtec9's Avatar
sorry I was tired.. I mean't gl-5 for the diff
edit: and apparently I'm still tired because I just stuck an apostrophe in "meant"
Old 01-20-2006, 06:35 AM
Squeezer's Avatar
DO NOT USE GL-4 or GL-5 Gear Oil in the transmission. It will eat the brass synchro's. use Honda MTF.
Old 01-20-2006, 06:50 AM
TubeDriver's Avatar
Amsoil used to (still?) make a 80w-90 GL-5 synthetic gear oil for the diff. I have used it and it seems to work fine. I have a case of it in my basement so I'll use it up before going to the LE stuff. I change my fluids frequently (oil at 3-4k miles with Mobile 1 10w-30, tranny every 8-10k with Honda MTF and diff every 8-10k Amsoil 80w-90 GL-5).
Old 01-20-2006, 07:12 AM
S2kracka's Avatar
[QUOTE=Squeezer,Jan 20 2006, 10:35 AM] DO NOT USE GL-4 or GL-5 Gear Oil in the transmission.
Old 01-20-2006, 07:16 AM
Jay2000's Avatar
Amoil 0-30 series 2000 is there best oil, it is better than there 10-30. It should not hurt anything, i believe the 0 part is the flow rate which is better than 10.
Old 01-20-2006, 07:18 AM
S2kracka's Avatar
The 0W basically means its thinner and flows better while cold. This helps circulate the oil faster, but it will not protect as well as a comparable 10W aslong as its warm enough for that 10W to flow/circulate properly.
Old 01-20-2006, 07:27 AM
Jay2000's Avatar
Isn't the 30 weight the running temperature when hot? So they are the same.
Old 01-20-2006, 08:11 AM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
I tried Amsoil in my AP2 trans and didn't feel any difference.
Quick Reply: amsoil...
