AMSOIL 10W30 impressions after 6K miles
Hey guys,
Just did my first full 6K run on AMSOIL Signature Series Full Synthetic. I wanted to post my impressions.
I drove the car 6 K miles, hit VTEC here or there. I baby my car and even more so after I had to do a diff replacement earlier this year. Over the 6K miles I added 1 quart to always keep the oil at the top X.
So it was getting pretty dirty so today I did a change with the same oil. I was shocked to feel the oil had not lost any of its viscosity or lube properties. 6K miles later this oil felt brand new with the exception of the color of course. I compared new and old oils and both felt identical.
I think I could have used this oil safely for another 6K miles without worry of engine wear. I’m very impressed because other oils like Castrol or Valvoline didn’t have the same feel from new to used oil. I could always tell the old oil had broken down some but not the AMSOIL.
Price wise the change cost me 70 bucks for the 7 quarts (1 quart as a spare) and 12.99 for the OEM filter so about 83 bucks. Sure I could have used Castrol Edge and saved 30 bucks but id rather spend the extra 30 to keep my motor clean and healthy.
I’m going to try 8K miles this time. And I won’t ever put any other oil in my car again or any future cars I own. Super impressed with AMSOIL and so worth the money.
the colour of used oil means nothing, don't ever judge an oil change interval based on colour. That oil can easily go 10k-12k miles and probably even longer. If you want to find out how long you should run an oil have some used oil samples analyzed at various intervals and you will get a good idea of how long to run your oil. It is money well spent IMO.
And yeah I think im gonna go to 10K on the fresh AMSOIL I did today...
You can take samples during the oil run if you like, it will be a bit more messy and you will lose maybe one quart depending on how long it takes to pull off the drain bolt and then reinsert it after taking the sample. Its not bad idea as long as you don't mind the mess, it doesn't take long to fill the oil analysis bottle that comes with the sample kit.
Glad you like the Amsoil SS oils....they are good stuff.Can easily go 15k miles or more.IMO....it's a good idea to change the filter half way thru your planned run.
What weight did you use? I run Amsoil 0w30 SS on my S2K,Z06 & GST.The EXV & CRV take the Amsoil 0w20 SS.
BTW....SS 0w30 is $8.15 qt ( Preferred Customer Price) and a good filter ( I use Wix #51334) is about $6.
\rlr
Carolina
\rlr
Carolina
Received 1,751 Likes
http://www.fumotousa.com
