am i f*cked? [[[UPDATE]]]
Old 11-02-2011, 10:11 AM
i_luv_s2k's Avatar
Default am i f*cked? [[[UPDATE]]]
So about an hour ago I leave for school....as I merge onto the freeway and get up to speed, at about 45-55 mph I hear a loud THUNK, then a loud whirring/knocking sound coming from the rear. At first I thought I hit something, but upon closer inspection I assume its either transmission/rear differential related...I put it in gear nothing happens...I try to accelerate while in gear whirring/knocking sound from rear starts up...am I f*cked? Damn I have a midterm today too! Any inputs? I'm hoping its's just the fluid because if not then I'm carless for at least a month Thanks in advance! peace (2002 AP1 75,000 miles) p.s. Anyone know of any socal car rental locations that dont require a deposit? broke baller yo! lol
[[[UPDATE]]]
hey guys well it turns out I am f*cked and it is my rear diff...now due to low funds I'm gong to have to rebuild it myself. I have not rebuilt a rear differential before, and couldn't find a diy for it. Anyone know of one? I'm very hesitant to tackle it before I have the right info/tools/procedures as it is/was my DD, short on time, and can't afford for it to break-down post-rebuild. So for from forum trolling the information I have gathered is:
- honda s2000 service manual is a must
- backlash/clearances need to be precise (any better than oem specs?)
things you guys think that is a mandatory replacement?
things you guys think can be re-used if still good?
parts/tools/procedures you guys would recommend for the repair?
I'm tired of sitting in my car on jackstands and making V-TEC noises lol! Thanks in advance! peace
Old 11-02-2011, 10:20 AM
Neuman04's Avatar
Im thinking rear Diff. You could drain the fluid to see whats in there.
Old 11-02-2011, 11:29 AM
305AP1's Avatar
Sounds like you broke the driver side axle ..
Old 11-02-2011, 12:46 PM
Pinky's Avatar
I heard that exact same description when I shifted from 3rd to 4th but I didn't accelerate just a boom/thunk......then the sound you described.
DIFFERENTIAL SPLOADED!(yes I spelled it right sploaded) Sorry for your loss.
Old 11-02-2011, 01:56 PM
stupkid's Avatar
Damn that sucks, most likely your rear diff.
I worry about mine everyday, but I still launch and do drifts every now and then Could go boom and day now ):
Borrow/rent a buddy's car for a while. Good luck man!
Old 11-02-2011, 02:34 PM
speedjunky01's Avatar
there is one in the classified for 300 shipped now and it takes a couple of hours to swap so not to crazy of damage.
Old 11-02-2011, 09:19 PM
hypforlife32's Avatar
i highly doubt it was his axle while he was moving from a roll, if it was a launch or a burnout then i would be pointing in that direction.
Old 11-03-2011, 05:30 AM
DFWs2k's Avatar
x2
and your fluid "going bad" wouldn't cause you to not be able to use your differential, so it's going to be expensive
Old 11-03-2011, 06:14 AM
Neuman04's Avatar
Originally Posted by DFWs2k
x2
X2 on the Fluid
Old 11-03-2011, 11:26 AM
Billman250's Avatar
Received 1,395 Likes on 836 Posts
Almost guaranteee this is your problem.
Look for a twisted CV boot on the axles. Twisted boot=broken joint inside.
Quick Reply: am i f*cked? [[[UPDATE]]]
