am i burning oil?
Old 11-15-2007, 02:42 PM
  #41
RACER's Avatar
One side of the dipstick will have more oil on it than the other side because it is at an angle. There can be oil on the sides of the dip stick chute days after the engine was last run.
When you check the oil level when the engine is warm, you are prolly picking up oil on the dip stick chute giving you a false reading.
I always go by the side of the dip stick that shows a lesser reading.
Old 11-15-2007, 08:34 PM
  #42
ShocK's Avatar
From my understanding when Honda built the AP1 engines they did not use a honing plate, which is necessary for proper honing to keep the cylinders in as much of a perfect cylindrical shape as possible. When you bolt the head down, the block may distort slightly, so to properly hone the block before putting the head on you use a honing plate that is about 1 or 2 inches thick and uses all the OEM mounting points and must be torqued to specs, this replicates the head and then you can bore the cylinder. Not doing so may cause the hone to lose symmetry, which is the main oil consumption problem IMO, if all this is true of course I'm surprised nobody has mentioned it.
Old 11-16-2007, 09:34 AM
  #43
jyeung528's Avatar
where did you get this understanding from?
i highly highly doubt this....
Old 11-16-2007, 07:20 PM
  #44
RACER's Avatar
[QUOTE=ShocK,Nov 14 2007, 10:03 PM]I dont really understand why you need to use the timeline aspect of it, how long does it
Old 11-16-2007, 08:05 PM
  #45
marlonRocks's Avatar
Originally Posted by RACER,Nov 16 2007, 08:20 PM
It's called oxidation. When the oil is sitting the shelf, it is sealed, away from contaminates.
Old 11-17-2007, 12:30 PM
  #46
ShocK's Avatar
Learn something new every day
Old 11-17-2007, 12:33 PM
  #47
ShocK's Avatar
Talk to any engine builder, its a necessity around a machine shop. I'm sure Honda could figure out a way to not use the plate and put pressure on the block while honing, Every AP1 I know of uses oil, you cant blame that much consumption on something silly like the PCV valve.
CoralDoc
03-27-2018 01:01 PM
stupkid
11-07-2011 03:12 PM
VTECorona
08-08-2004 08:43 PM
cajun_mike
09-11-2001 12:33 PM
s2ktaxi
05-14-2001 06:02 AM
Quick Reply: am i burning oil?
