Alternator needs replacement?
#21
Unless the lacquer has failed and there's a short (or a wire has broken and you have an open), the rectifier is the most likely piece to fail (being solid state).
Open up the alternator and swap out the parts. It's not like we can give you a blow by blow account on how to open one up, just grab a service manual to see an exploded view, or just start disassembling.
#22
Just bringing this back up hoping someone has a DYI on how to replace the rectifier.
Today when I was approaching a dip, car was in neutral, I look down and saw that my car wasn't on and it shut off. It turn back on immediately after and continue on to my garage.
In the garage, I notice that my gauge was lightly flickering at idle however with any increase in RPM, the flickering went away.
Nothing has been changed to the car. I'm assuming this is the rectifier in the alternator that needs to be replaced. I looked up the price of an alternator and dang its over 1k or 900 at invoice.
Is it hard to remove the alternator? and can someone confirm that this is my issue?
#23
had a chance to look at the service manual last night. It isn't too bad removing the alternator and taking it apart. I'll be ordering the part.
Today driving to work, i can't tell at all if the gauge is flickering. Yesterday when it flicker, you can't really tell at all, its very sutle. You have to really look up close.
Can it be heat related?
just want to make sure this part is the problem or if I have other issue. can someone confirm please. Thank you.
#24
Since posting this up last week, the symptom somehow went away At idle, the faint flicker isn't there anymore.
I'm going to check the grounding point and cleaning it out. The grounding point is in the front passenger side?
