Alternator bolt size question?
What size is the upper altenator bolt as mine stripped and i wanna get it replaced. im looking on majestic honda and it doesnt show it.
Bolt size and pitch: 10mm X 1.25
Bolt length: 45mm
Bolt head size 14mm (never used in bolt sizing)
It will likely be called a 10mm X 45MM bolt on a website or hardware store. but the pitch must be 1.25.
Bolt length: 45mm
And at a hardware store, it will likely be a US/European spec with a 15mm head, rather than an Asian spec with a 14mm head. But if it's the right diameter/pitch/length the head size is unimportant.
The alternator bolt is also sort of pointed. Not sharp pointed, but like a cone with no point.
It is 10mm*45mm with a 14mm head.
There's other 10mm*45mm/14mm head bolts on the car that are NOT pointed, though. I don't really know the reason for the point, but I'm guessing the hole its in needs that point?
P/N is 90032-PCX-000
You can order it from Majestic...just search by P/N instead of model
