Alternator/Battery problems.
Old 09-02-2010, 12:32 PM
turbo_slug's Avatar
with the car running, use a multimeter to measure the battery voltage. it should be around 13.8V-14.4V. now put the multimeter into AC Voltage mode. measure across the battery again. you should measure 0V. if you see voltage while measuring in AC mode, the diodes are bad.
Old 09-02-2010, 12:42 PM
Saki GT's Avatar
Unless you're already replaced it, you have a six year old car with a 5-yr battery in it. I'm going to go out on a limb and say its an old battery. You are taking a simple problem and making it way too complicated.
Old 09-02-2010, 02:24 PM
[APtwo]'s Avatar
So I took it to auto zone and they said my alternator is fine. I'm still a little skeptical because my tach sometimes flicker during idle. It isn't that noticeable but enough for me to see it.
Old 09-02-2010, 09:17 PM
Mister Jew's Avatar
Originally Posted by toniotran,Aug 30 2010, 11:30 PM
I believe you can check by removing the negative terminal off the battery after you've started the car and if it the car shuts off then it's usually a sign of a bad alternator...plus you'll know if it's the alternator now if the car begins having start up issues again since your dad replaced the battery. hope that helps
You've got it backwards. Start car and remove the positive battery cable not the negative.
Old 09-02-2010, 10:36 PM
toniotran's Avatar
checkout step 2
http://www.wikihow.com/Check-an-Alternator
Old 09-03-2010, 03:05 AM
dr.s2k's Avatar
er, it won't matter which terminal you disconnect?..
Old 09-03-2010, 04:56 AM
idea-catalyst's Avatar
Actually, it does matter but perhaps not for the reason that you are thinking.
Removing either cable will disconnect the battery. If you remove the positive cable, you have this "hot" post sticking out; touching anything to it that is also connected to the car will give you a short - and a good size spark. If you remove the negative terminal, all of the "positive" connections to the battery are still insulated. Accidentally touching the negative terminal of the battery to something connected to the engine or chassis merely reconnects what you have disconnected.
Disconnecting the negative terminal reduces the likelihood of receiving a nasty surprise with a dropped wrench or other metal tool.
Old 09-03-2010, 11:36 AM
MasterForce's Avatar
thats why you always disconnect negative first and connect last.
Old 09-05-2010, 04:28 PM
[APtwo]'s Avatar
Ermm, so which one do I disconnect?
Old 09-05-2010, 05:39 PM
2leftshoes's Avatar
negative always hi jason
Quick Reply: Alternator/Battery problems.
