Alternator
Alternator
Can someone please help me with a DIY alternator install.I've searched and read the DIY's and 9 pages of the techinal thread and still cant find anything about the alternator.It went bad...I pulled it and had it replaced and I cant get the damn thing to go back in.Is a special tool needed or something?I know it sounds retarded but the bottom wont go into the bracket..I've tried everything>Some pictures of an install would be VERY helpful...or any advice.Cars just sitting in the garage right now until I get a response that may help.Thanks ALOT in advance..
Bill
Bill
ok well I got the alternator in.NOW can someone PLEASE help me and give me some advice as to whats wrong with my car?Long story short......the car died while driving..threw an EPS,ABS light, all the lights dimmed and the car just died.Had it towed to a shop and was told the alternator was bad but the battery was fine.had them instal a new alternator.2 weeks later the car did the same thing.Pulled the alternator myself and installed a new one yesterday...the car still wouldnt start.Pulled the battery and took it to advanced and was told the battery was bad..was only holding 2 volts under load.Bought a new battery and installed that.The car ran fine yesterday.Just drove it about 6 miles and all was well.Cut the car off and now it wont start.PLEASE someone help...Thanks
Bill
Bill
I had the same problem once. Check your alternator fuse in the fuse box under the hood. It has to be blown. Secondly you probably have a short somewhere which is causing it to blow so you gotta trace that. I had this problem because of the solenoid with the two small vaccum lines got into the serp belt and ripped out the wires shorting it out. If you have a cold air intake it is a good chance you might have the same problem.
Bill
It really seems like the fuse. If you keep installing alternators and they dont work its because the fuse is keeping power from the alternator to get to the battery. Therefore you car will just run on the battery until it dies.
one possiblity for both of you guys having trouble is that the battery might not be fully charged. when the battery sits on the shelf at the store, over time it looses charge. the amount of driving you did with the new battery in might have not been enough to fully charge it. have either of you tried either charging the battery or getting a jump and letting the car idle/drive it around for a while?
james
james
Yep your car is doing the same thing mine is.I checked the fuse and Im positive that the fuse is not blown.Checked all wires that I could and traced them fromt the wiring harness and nothing seems to be out of place,cur,or touching something that it could short out on.When I disconnected the Pos terminal the car just died.It started again today when I got home but hesitated on the start.Does that mean another alternator is bad?Man I need some help....
james
james
