Alingment advise after tein s-tech
#31
you really shouldn't be rubbing at all with those tire specs and sizes. I was on the exact same thing and I did rub/flare my fender a bit only on one side while at the track but for street driving, no way.
get an alignment and you will be laughing.
#32
I'm running the same wheels (in Mercury Silver) with Michelin PS2s in 225/255, and I haven't rubbed once. Lowered approx. 1" on Bilstein PSS9s. Running a more or less stock alignment, with 1.8 degrees neg camber in the rear.
Does the tire you're using have a very square edge profile? That's about the only difference I can think of, short of suspension parts being bent or otherwise out of whack.
#33
My tires do have a good contact patch but they are not and I had the allingment checked before I lowered just to be safe that there is no damage to any suspension components and my car was perfectly within spec aside from one side sitting a tiny bit lower which is normal apparently.
#35
one time i had a passenger, and i went up a driveway................ and the fronts more than rubbed--they totally bent out the fender on the passenger side. so, i would say +50 with j's camber joints in front could result in damaged fenders, even at -3deg camber. oh well--now i have an excuse to get a widebody kit.
rijowysock
01-05-2006 06:13 PM
