Is this an alignment issue ..... need Advise!!
Old 03-31-2002 | 02:29 PM
Mclaren's Avatar
Default Is this an alignment issue ..... need Advise!!
On acceleration - not hard, just cruising, the car pulls to the left, when I let off the gas it over corrects to the right - almost a wobbly, chassis / alignment issue - I think.
Has anyone else had this issue - or - do you have any thoughts as to why this may be so.
It's a 02, with about 2000 miles .....
Thanks for your advise.
Old 03-31-2002 | 02:38 PM
Pappy's Avatar
I had the same problem. It is the rear tire pressure that is the error. Check the psi of each tire. I have mine set to 32 psi per tire.
Old 03-31-2002 | 04:45 PM
CoralDoc's Avatar
! What Pappy said ! I'd check all 4 to be sure, though.
Check your tire pressure and report back here to let us know if that was it.
Old 03-31-2002 | 06:07 PM
jschmidt's Avatar
It's rear tire pressure. It's on the side it pulls toward. And it's most likely a nail in the tire. Been there and seen it about a dozen times here.
Old 04-01-2002 | 10:16 AM
Mclaren's Avatar
Wow what a difference w/tire pressure. The rear right was very very low - nearly flat! Cured the issue.
Thanks for your input, much appreciated.
Old 04-01-2002 | 01:14 PM
astig00's Avatar
That has happened to me too. Only my tires were not the same in rolling diameter even though they were the same size
Brian_08
04-08-2012 05:21 PM
skizzo82
07-21-2008 12:38 PM
BlownAP
04-09-2008 12:38 PM
jsebastiant
11-13-2006 07:20 PM
Jaydem
02-14-2006 09:57 AM
