Alignment Help
Alignment Help
Got new tires and had my alignment checked. The car felt good but this being the only s2k I've really driven aggressively, I thought I'd have it checked out to make sure everything is good. As there are lots of twisties where I live I also wanted to give the eur alignment a try.... so I wrote out the Euro specs and gave it to a tech at a local Honda dealership. I asked him to show me the specs before adjusting... instead, he ended up just adjusting and gave me the 'before' after he was all done.
Here's how it had started:
Front
Caster Left 6.28°
Caster Right 5.45°
Camber Left -0.57°
Camber Right -0.47°
Toe Left 0.12°
Toe Right -0.21°
Total Toe -0.09° (toe out)
Rear
Camber Left -1.76°
Camber Right -1.43°
Toe Left 0.38°
Toe Right 0.24°
Total Toe 0.62° (toe in)
Here's the after:
Front
Caster Left 5.86°
Caster Right 4.95°
Camber Left -1.01°
Camber Right -1.00°
Toe Left 0.01°
Toe Right 0.02°
Total Toe 0.03° (toe in)
Rear
Camber Left -1.78°
Camber Right -1.66°
Toe Left 0.20°
Toe Right 0.20°
Total Toe 0.40° (toe in)
*actually when he was done and gave me the after sheet, rear toe was 0. I asked them to confirm the sheet and it turned out to be a mistake. They realigned it for me, leaving me with the above specs.
Overall the car feels very good. Lots of grip in corners. The back end feels like it holds very well. I also changed out some near-bald RE01R for Direzza Star Specs so I'm pretty sure that has a lot to do with it too.
The Problem: Sometimes the car doesn't feel as stable as it did, and the effect is more pronounced at higher speeds. One definite issue I've noticed is that if I turn the steering wheel sharply and let go, the steering wheel will not just snap back to center - it will go past that to the other direction and the entire car will wobble as opposed to just stop turning. So instead of just coming out of a turn the car will wobble a few times before settling on a post-turn direction. It didn't do that before.
I'm not sure what the cause of this is. Any suggestions would be appreciated..
Front
Caster Left 6.28°
Caster Right 5.45°
Camber Left -0.57°
Camber Right -0.47°
Toe Left 0.12°
Toe Right -0.21°
Rear
Camber Left -1.76°
Camber Right -1.43°
Toe Left 0.38°
Toe Right 0.24°
Here's the after:
Front
Caster Left 5.86°
Caster Right 4.95°
Camber Left -1.01°
Camber Right -1.00°
Toe Left 0.01°
Toe Right 0.02°
Rear
Camber Left -1.78°
Camber Right -1.66°
Toe Left 0.20°
Toe Right 0.20°
I just did my car a couple days ago at our Honda dealer, but I don't know how the Euro specs compare to ours in N. America. Here are my comments.
The after numbers do look better at least the toe settings aren't working against eachother from front to rear, much like mine were doing prior to the alignment.
Firstly, I don't think there should be any caster, as far as I knowit should be 0 at least it is on my car. Secondly, camber is non-adjustable so it is what it is, and your camber doesn't look too bad, good for handling, you may get a tad bit of wear on the tires but probably not too bad.
As far as toe, my front was set at perfect zero toe after the alignment, the rear had a bit of toe on it, but total toe worked out to zero on both front and back, not sure how that works. And they had a listing that stated that the car steered perfectly straight. I can refer to my alignment sheet to get the exact numbers later tonight and I will post it.
Originally Posted by fuel4blood,Oct 27 2009, 12:48 PM
Why are you saying camber is none adjustable? Do you mean caster?
With my sheet in front of me my alignment numbers after alignment were as follows:
Left front - camber .40 deg, caster - middles of spec ? can't read any number, toe - 0 inches.
Right front - camber -.43 deg , caster - middle of spec ?, toe - 0 inches.
Left rear - camber -1.4 degrees , toe - 1/8 inches.
Right rear - camber -1.52 degrees, toe - 1/8 inches.
Total toe front - 0 inches
Steer ahead front - 0 degrees
Total toe rear - 1/4 inches
Thrust angle - 0 degrees.
The arrow I drew in paint is to the camber eccentric bolt. The one clearly pictured if the adjustment for caster
This is a horrible example. I tried to paint a nice eccentric for caster. This is a clear picture of front camber adjustment.
The rear on these cars are tricky to say the least! There is an eccentric for camber and toe. Both have to be moved the the same time in order to achieve a great alignment. This means if I move camber to -1.00 then toe to +.30 camber will be way out.
Hopefully these shop manual pictures help your case. If you need mw to get you any more, or want the unaltered version I'll be happy to send you them.
Originally Posted by JFUSION,Oct 27 2009, 06:37 PM
thanks for that info Importkid, that is very helpful, I stand corrected !. Perhaps my dealer meant that they couldn't get the camber adjusted any better than it is without affecting the other numbers.
g35s2000
08-13-2009 06:40 PM
