Aligned
Aligned
Had it aligned... How'd they do? Anywhere I should adjust next time around?
Front - Left / Right
Rear - Left / Right
- Camber: -.41 deg / -.45 deg
- Caster: 5.68 deg / 5.9 deg
- Toe: .01 inches / .0 inches
- SAI: 8.9 deg / 9.57 deg
- Included Angle: 8.48 deg / 9.13 deg
- Cross Camber: .04 deg
- Cross Caster: -.23 deg
- Cross SAI: -.68
- Total Toe: .01 inches
Rear - Left / Right
- Camber: -1.37 deg / -1.52 deg
- Toe: .12 inches / .12 inches
- Cross Camber: .16 deg
- Total Toe: .24 inches
- Thrust Angle: .0
I personally like them more equal (I have issues) so that they are within 1/100th of each other for the camber, although having the toe more equal is more important for handling and tire wear.
I forget what they are, but if you've looked, the UK alignment settings seem to be the most favore around here.
Bassem
Bassem
Kaneda215
08-11-2011 09:16 AM
