Air Pump removal=check engine light, anyway around the CEL?
Originally posted by Prolene
That test pipe might cause a limp home mode...or just cel... or tune issues?
Originally posted by ugotmade
Any other good reasons for removing it?
Originally posted by vapors2k
Going to try installing the relay assembly back in and see what happens.
there's more than 2 wires. There' the pump assembly and then there is another (what looks like) a relay assembly. I removed all of them. Going to try installing the relay assembly back in and see what happens.
Originally posted by coquinn
You still get the light w/ the Spoon ECU as well if you have a test-pipe ...still trying to figure that one out.
-Brian.
Originally posted by bmarshall
Put the secondary O2 sensor in the decat pipe, and you'll no longer get the CEL with the Spoon ECU.
I did this and it did not resolve the problem. I am getting a weird JDM-related CEL code (nothing in our manuals to describe such code). I believe the ECU is looking for something that is not present on the USDM cars - as opposed to the European and JDM vehicles.
I believe Chris from Science of Speed had this problem as well.
Thanks for the advice though.
Brian:
Brian:
-Brian.
