Air Pump removal=check engine light, anyway around the CEL?
Air pump was removed, this helps get the cat heated up faster on cold starts. I removed everything in that area, the pump and what looked like to be a relay. First start of the car and all is fine. After the second start, check engine light pops on.
To those that have removed the air pump, do you get a check engine light?
tia,
-ardy
tia,
-ardy
Krazik removed the air pump as well and says everything was fine at BW, though the CEL was lit. I know of no workaround for the light. I'm not sure what I'm going to do if I put the stock ecu back in, since the Mugen ecu does not set off the CEL for this.
Originally posted by vapors2k
the CEL didn't affect the car in any way. Damn the CEL, I was CEL free until now. I might as well try that test pipe and see where I'll be.
You just get the light w/ a test-pipe ...no limp mode (at least here on the east coast).
You still get the light w/ the Spoon ECU as well if you have a test-pipe ...still trying to figure that one out.
i havent had my airpump taken out.. but i disconnected it and put it back together and nows its giving me a check engine line.. for incorrect secondary flow or something like that.. this is the second time.. once when i had my CAI and now with my turbo.. i know that the airpump is for emissions.. i would also be interested if there was a way to bypass that CEL from removing the airpump
How many wires (pins) are in the air pump's harness. If there are only 2 wires, then I think the ECU just checks for a current load from the air pump. The only way to fool it would be to find a REALLY high wattage resistor to put accross the air pump's power leads. If there are more than 2 wires, then it could be more complicated (fan motor RPM wire, etc.).
