Air pump problem ?
Old 04-29-2011, 04:36 AM
  #21
Billman250's Avatar
Received 1,401 Likes on 839 Posts
Not the valves.
Not the air pump.
Not the cat.
You have a bad front o2 sensor right out of the box, a bad wire or conection to that sensor, or a bad ECU.
Your 5 flashes are for a failure of the 02 heater circuit in the front sensor.
There is NOTHING else it can be. Thats it!
Old 04-29-2011, 04:37 AM
  #22
Billman250's Avatar
I would check your wire continuity all the way back to the ecu. If you want your car fixed, you will do just that.
Old 05-01-2011, 04:17 AM
  #23
tobbe__86's Avatar
Thanks boys i have à bad ECU
Old 05-01-2011, 05:37 AM
  #24
s2klariat's Avatar
Look around on the net. I found a very low miles ecu when mine kept throwing a CEL for the po411 code for only 75$
dagle
06-12-2015 12:39 PM
Terrence Millner
06-27-2009 03:40 PM
Toda R
03-26-2009 11:06 PM
jinjer
05-26-2006 04:19 PM
Quick Reply: Air pump problem ?
