Member S2000 Classifieds and For Sale
Air pump problem ?
S2000 Technical and Mechanical discussions.
Air pump problem ?
04-16-2011, 03:05 PM
Slows2k
P0135 has absolutely nothing to do with the air pump. You have a issue with the primary 02 sensor heater circuit.
Like
Slows2k
Find More Posts by Slows2k
04-16-2011, 03:18 PM
s2000maniac
i'm suprised nobody is mentioning the catalytic converter ......
Like
s2000maniac
Find More Posts by s2000maniac
04-17-2011, 07:29 AM
13
Slows2k
The Primary sensor is in front of the converter, when the converter breaks it damages the rear sensor.
Like
Slows2k
04-18-2011, 01:57 AM
tobbe__86
So i can have a bad ECU??
Like
tobbe__86
Find More Posts by tobbe__86
04-18-2011, 09:28 PM
15
tobbe__86
I hava raight volt and om on the sensor. So wat schuld i do?
Like
tobbe__86
04-20-2011, 02:08 AM
16
tobbe__86
I have the service manual to s2000 00-03. And my car is à 04 can i use this to trobbleschooting my 02 sensor?
Like
tobbe__86
04-27-2011, 04:05 AM
17
tobbe__86
can a bad map sensor do the problem?? my sensor is verry bad.
Like
tobbe__86
04-27-2011, 04:49 AM
18
AngryTurtle
Slows2k
You've got a issue with the primary 02 sensor heater circuit, not the air pump. Did you install a new Honda sensor?
Slows2k
Slows2k
Maybe he has the vacuum lines on the air pump backwards?
Like
AngryTurtle
Visit AngryTurtle's homepage!
Find More Posts by AngryTurtle
04-27-2011, 10:10 AM
19
tobbe__86
i clear the cod and just hav the ignition in 2 not start the engine end after 1 min the cheek engine light will flash 5 times what is that??
Like
tobbe__86
04-28-2011, 10:03 PM
20
tobbe__86
I havent do the valve ajustmen can it be the reason?
Like
tobbe__86
Posting Quick Reply - Please Wait
Quick Reply:
Air pump problem ?
The following errors occurred with your submission
Okay
Quote message in reply?
04:21 AM
