AIR PUMP engine management light
Engine management light came on a while ago, car has been in with Honda a couple of times and as the car was in a crash previously (insurance approved repair) Honda have said the air pump and wiring loom were possibly damaged. This of course means they are saying it is not covered by warranty... I remember seeing something on here before about airpump/engine management light and cant find it, obviously my worry is that this is a common problem and I should be pursuing the warranty claim. Has anyone else had this problem? Any comments regarding warranty would be appreciated....
I wish you luck in your quest, however, in most cases, whenever a vehicle has been in any kind of major collision, regardless of where the impact was, manufacturers have a tendency to void the whole warranty citing that such a collision can do damage that can not be immediately determined.
Well, the air pump sits right behind the driver's side of the bumper, below the headlight. So if the crash was frontal, it is likely damaged. The adjuster should adjust
bump, good luck on your probs!
i had the same problem when a guy hit me in the front corner. smashed the air pimp and damaged several wires on the wiring harness to it. bodyshop didn't fix it, took 2 dealers to fix it. your insurance from the wreck should cover it because its from the collision damage.
Not uncommon.
Originally Posted by Tinker219,Nov 26 2004, 08:30 AM
My car as also in a frontal impact, and the pump was replaced, which leads me to beleive I have a Xed line somewhere(or a hole?).
Did you try resetting the CEL? I had one case where a shop disconnected the air pump, started the engine, set the code, and then reconnected the air pump. System was actually working fine, but I think once the code is thrown it stays thrown. I reset the ECU and all was fine.
If you reset the ECU (or have the code cancelled) and it comes back, then you definitely have a problem that needs to be fixed. But if you reset the code and it doesn't come back, you are good to go.
Originally Posted by mikegarrison,Dec 10 2004, 01:20 PM
Prob a misinstalled hose.
Originally Posted by Slows2k,Dec 10 2004, 04:04 PM
A P0411 is a 2 trip DTC. 2 warm up cycles are required to throw the DTC. The coolant temp has to be between 32 - 158deg F. for the air pump to run at start-up.
The car had been in to get the motor mounts replaced, so they had to lift the engine up a bit. I'm assuming they disconnected the air pump lines to get enough compliance.
