Air Filter
Old 02-23-2001, 05:52 PM
  #21
RT
RT's Avatar
can I have it?
Old 02-24-2001, 05:55 AM
  #22
S2000 Driver's Avatar
I hesitated bringing this up but now that it has...
I bought one of the JR Air Filters and it is not a drop in!
Maybe I'm the exception rather than the rule here but I define "drop in" as simply that -- DROP IN, i.e., requires very little to no: crushing, squeezing, cramming, jamming, cutting, or whatever to install.
By my definition the JR Air Filter is certainly not a drop in. I have not complained or requested my money back because, quite frankly, I can survive the $65 loss or whatever it was. However, I will be much more wary in the future about buying merchandise online.
Maybe I'm just more exacting than most people!
[Edited by S2000 Driver on 02-24-2001 at 06:58 AM]
Old 02-24-2001, 06:41 AM
  #23
Big Al's Avatar
Mine dropped in with no problems at all. It was 60 degrees F in my garage when I put it on but it took all of 5 minutes. No band-aids, cursing, or misc. other bvllsh!t to make it work! Quality is also excellent.
Old 02-25-2001, 01:43 PM
  #24
exNSX's Avatar
Some cramming definitely required here but I think I got the airbox to seal up OK. I may give it another go when the weather warms up. If there's a performance gain it's pretty subtle. I didn't expect too much - but had to do it anyway.
Old 02-25-2001, 09:25 PM
  #25
ultimate lurker's Avatar
I had the easy install too. We put mine in at the Manhattan Beach, CA get together. 60 F day. Took the cover off, popped out the old filter, spent 20 seconds fitting the new filter and we were done. It does take a push, and I could see it being tough in cold weather, but it was a install and forget mod.
I think Richard dyno'd 2 hp worth of gains. Combined with the reusability, it's probably worth it.
UL
Old 02-27-2001, 12:11 PM
  #26
STL
STL's Avatar
[QUOTE]Originally posted by E30M3
[B]>>I have the JR and it WAS a drop in replacement.<<
Not with the airbox / JR filter we tried out.
Old 02-27-2001, 07:56 PM
  #27
dgl1's Avatar
While I live in N. Calfornia, temps have been close to 32 deg. My JR filter arrived in mid-January. Having read Luis' caution about the mounting post, I applied light grease to both the post and the stack that is inserted in the air tube. Worked great. A little lubrication goes a long way.
dgl1
Old 03-01-2001, 12:13 PM
  #28
mingster's Avatar
[B]The filter itself seems to be well made.
Old 03-01-2001, 12:43 PM
  #29
Zippy's Avatar
Mine dropped in at ~35F. I had no problems with the stock air box and am very, very please with the unit.
As to Pinky's question, can there be a difference with the stock air box. The dyno tells the tale. Mingster posted the printout a few weeks back. It seems to make more difference that the CAIs that I have seen dynoed on this board. I believe that it seems to rev a little smoother, that of course is my perception, but again look at the dyno sheets.
To all who had a tough fit- you might check to see if there is a problem in your air box.
Old 03-01-2001, 08:26 PM
  #30
Silver S2k Guy's Avatar
Well if any of you guys that are having problems with your JR filter wanna sell it, I'd be more than happy to take it off your hands. I'm taking delivery of my stook Monday and already I'm ready to start modifying!
~Seth
Quick Reply: Air Filter
