Air Conditioning
Air Conditioning
After un-installing the Vortech SC, the air conditioning fan seems to not be working. I had a guy fill it up with 1-3/4 pounds of Freon, so that is full, but I dont even fill the fan blowing. The dude said that it could be lots of things which can cause this. One is could be a blown fuse or electrical problem.
Has anyone ran accross this problem before and is there any quick simple solution? Else, I'm bringing it to the dealership since I still have warranty, but dont know if they'll notice that the Vortech SC kit used to be on the car.
The refrigerent level has nothing to do with the actual blower motor in the car. Unless the system was evacuated correctly before charging, the system is now overcharged.
The aftercooler pump was wired to the Blower motor relay in the underhood fuse box. Most likely your wiring is screwed there.
Fix why the blower doesn't run, and then take your car to a reputable shop to have the correct amount of refrigerant put back in.
MadDane
Member S2000 Classifieds and For Sale
08-20-2003 10:40 AM
