Air Conditioner Question
I have a MY02 with 37,000 miles. The air conditioner is very cold but one can feel a difference in the "quality" of the air when the compressor cycles off. When the compressor cycles back on, the air is very cold again. I had the AC checked and the shop advised me everything is okay. I called the local Honda service dept and was told this is characteristic of the s2000. Does anyone else have this same characteristic?
When the compressor normally cycles off the outlet temp will slightly drop.
The AC system is designed to cycle on and off, unless the system stops cooling all together, don't worry about it. It's normal.
