air baffel removal
air baffel removal
Is there and air baffel in the S2 that I can remove? If so has anyone done this and what effects does it have on performance and sound?
Are you talking about in the airbox? If so then YES, but I called it a divider. Anyway if you cut it out along with the "L" shaped thing on the lid, you will get a nice growl under acceleration.
Not sure about the performance increase so much. The sound is quite nice though.
Paul
Paul
Thanks, I dont want to compromise the protection the airbox give to foreign debris. I removed the air baffel and resinating chamber in my old CRX and there was a definate power increase and it sounded awesome. The only thing I did to my S2's airbox was block the small square hole under the filter in the airbox that I think was the resinating chamber. What L shaped peice are you suggesting I cut out?
