Aftermarket fuel rail?
Old 05-04-2007, 03:56 PM
SOHCmyDOHC's Avatar
Skunk2 supposedly has one.
SOHCmyDOHC is offline
Old 05-04-2007, 05:13 PM
Slows2k's Avatar
Originally Posted by CarbonS2000,May 4 2007, 05:33 PM
wow you can kiss my ass bc i never said i was gonna turn them down with the FPR....what point would that serve? you need to relax and keep you ego in check.
You need to calm down. Personal attacks are against S2ki rules.
Since you have your answer, this is done.
Slows2k is online now
Old 05-04-2007, 05:27 PM
AusS2000's Avatar
Hey, didn't mean to cause a ruckus.
I'm not sure what you mean by 'upgrade' the injectors. The stock ones do such a good job Hayabusa turbo guys use them in their mods. They have adequate fuel flow for NA and a good spray pattern.
Now if you are planing to install injectors in preparation for FI you would want larger ones. 550s or 750s perhaps. And if you just install larger ones you car will run pig rich. But you mentioned using an FPR so I assumed you would use it to correct the problem you caused with injectors spec'd for FI.
So I apologise if you didn't know the implications of upgrading injectors and the ghetto method of correcting it. The JDM forum is calling your name.
AusS2000 is offline
Charper732
02-28-2019 09:08 AM
ROFLv8
01-31-2014 04:52 PM
2QYK4U
11-12-2006 01:40 PM
speedy4cyl
03-16-2004 11:13 AM
AndyDoh
10-02-2003 06:27 PM
Quick Reply: Aftermarket fuel rail?
