After valve adjustment = strange noise
Originally Posted by smile,Jul 30 2004, 04:53 PM
gernby -- The shop that did my valve adjustment is very knowledgable and have worked on all of my cars without any problem.
Questions -- will there be a problem if I continue to drive as is? If I go to a dyno this weekend, will I put the engine at risk since the valves are possibly misadjusted?
If they did measure the clearance in the wrong location, I don't think there would be any damage for you to drive it that way. I drove mine that way for about 5K miles. I didn't realize there was a problem until I went to the dyno. Having excessive valve clearance taxes pre-VTEC power big time, but has little to no effect on post-VTEC power. During our local S2000 club dyno day, I was only 1 HP below the top in peak power, but I was almost 25 HP below the top in pre-VTEC power (at the very bottom of the pack by about 15 HP). None of the S2000s that were dyno'ed that day had any significant mods.
BTW, your smooth idle is another indicator that your valve clearances might be too high. Excessive valve clearance reduces valve lift and duration, which is great for low throttle, low RPM operation.
