after trans fluid change, 1st & rev difficult
Old 12-14-2014, 05:34 AM
Car Analogy's Avatar
Received 1,439 Likes on 1,071 Posts
Originally Posted by afzan
Any chance you didn't put enough into the tranny? Or that it leaked out somehow?
Issue first occured minutes after the fluid change, on first drive after. So it can't be a leak thing. I had car level, and waited until it started to pour out before closing it up. Plus it took about same amount as previous change. So I would be surprised if its low. But easy enough to check that.
Old 12-14-2014, 07:02 AM
Topplayer's Avatar
try bleeding the clutch line
Old 12-14-2014, 06:49 PM
I can try that, but keep in mind it shifted fine right before the trans fluid change, did not right after. Why would clutch hydraulics get air during this process when clutch was not touched?
Old 12-14-2014, 09:03 PM
XxMerlinxX's Avatar
Check the clutch master cylinder to see if it's leaking?
Old 12-15-2014, 03:50 AM
I checked it early on. No leak. Also its rather new. Replaced it a bit over a year ago.
Gotpepsi
06-27-2015 05:15 PM
watchdogd
09-06-2009 06:36 PM
s2kvince
04-10-2009 09:56 AM
jdmjeff
01-11-2009 07:38 AM
Quick Reply: after trans fluid change, 1st & rev difficult
