After Oil Change Car Still Rough, What Other Things Should I Change 4 Smoother Idle?
Yes I did them myself and it was a pain in the butt. The clearances were off from .001 to .003 if I remember correctly. It idles so much smoother it is unreal. My brother who had a s2k also noticed the difference right away.
jojipoji,
Did you use the special tool that is available? How cold was the engine-was it driven that day? I am doing mine very soon. Just want to know as much as I can before I start.
Banned
Change the spark plugs,
Clean the Throttle body and butterfly
Clean the IAC(Idle Air Controller)
Add some fuel injector cleaner
Clean your Air filter
Adjust valves
And then Reset your ECU
Your car will run like a champ
Someone tell me how changing tranny fluid, diff fluid and brake fluid can smooth out idle????/
Adjust valves
Originally posted by Tugz_S2K
. . . Someone tell me how changing tranny fluid, diff fluid and brake fluid can smooth out idle????/
Thomas Guide
04-03-2014 07:01 PM
